New DOT Approved ORA Night Guard LED Headlights!
Former Vendor
Upgrade your inadequate stock Jeep headlights with our new DOT legal ORA Night Guard LED Headlights! These are the newest version of the ones we previously announced here on the forum.
Notes: The anti-flicker harnesses we have available are recommended for 2007+ Jeep Wrangler JKs; they are the safest and most affordable harnesses on the market! Also, the running lights do automatically turn off when the headlights is turned on. The running lights can be spliced to the Jeep's parking lights or run to a separate switch.
-Exact Specifications
Beam type: High/Low Beam with Running Lights
Operating Voltage: 12V or 9-32V DC
Waterproof rate: IP 67
26 High Intensity Cree LEDs
Color: Black Housing and Reflectors
Color Temperature: Approximately 6500K - White
Added Lights: Daytime driving and Parking Lights
50,000 hours average LED life time
Dimensions: 7 Inch Round
Raw Lumen: Total ~ 6000
Now for the best part; the pictures. We will be adding more pictures which show the beam pattern in a few days, but they have a great cutoff and "teardrop" pattern!
Also available with the headlights are our LED fog light bulbs, which can be added as well to aesthetically match the headlights. We also have some full replacement LED fog lights coming out shortly.
If you are interested please reply with your shipping zip code/country for a quote to be sent via private message. You can also check them out on our website. Thanks!
- Direct plug-n-play with the factory wiring harness and plug; installs in minutes and no hard wiring required!
- Certified to the Department of Transportation specifications! DOT SAE stamp on the lens.
- Daytime running lights included, without buying costly aftermarket accent lighting or halos.
- Running lights can be used with a separate switch or as constant running lights.
- Low beam gives off a wide beam pattern and high beam gives off a powerful spot beam.
- Designed to fit may different style vehicles utilizing a 7" headlight.
- Breather vent allows pressure equalization without compromising waterproof and dust proof rating.
- IP 67 waterproof rating ensures a water tight headlight which will not fail due to moisture or dust intake.
- A one year full replacement warranty provided by Off Road Additions LLC gives the customer the confidence in a quality product.
- 4D optics spread light where it is needed most in an optimal pattern.
Former Vendor
We will be getting some great night shots this weekend, and will promptly post them up here on the forum!
We have decided to offer free shipping to all forum members on these lights from now until the end of Cyber Monday, on November 30th! We will send the coupon code to any member who requests a quote. Thanks everyone!
