New Product from TeraFlex! JK Rzeppa High Angle Factory Replacement Kit
Sponsoring Manufacturer
The TeraFlex JK high angle Rzeppa factory replacement CV joint kit allows the JK owner to replace a worn or damaged Rzeppa CV joint and retain their factory JK driveline without an expensive upgrade. The high angle CV housing reduces boot failure associated with taller lift heights. This is especially important on JKs with 3 or more inches of lift.
This kit includes the CV joint assembly, high-angle CV housing cap & boot, bolt flanges, socket head bolts, 6mm allen wrench, and low-friction CV grease engineered specifically for the high RPM needs of the JK Rzeppa CV joint. The grease features high viscosity surface bonding characteristics required to properly adhere the grease to all moving surfaces.
These will work for both front and rear drive shafts and both ends.
#1744014
$149.99 retail
In Stock
BUY NOW!https://teraflex.com/shop_items/55c3...a25c5bb1173c17
https://www.youtube.com/watch?v=AXc9285oTls
#1744014
$149.99 retail
In Stock
