Now Available - 7" LED Headlights - DOT Approved (10% OFF for JK Forum Members)
Former Vendor
DOT 7" Headlight (Pair) - 4x4TruckLEDs.com
Well it's been long awaited but it's finally here. Diode Dynamics just launched their DOT Approved 7" Headlights! This style is THE most popular LED Headlight we see Jeeps using. But now it's from a QUALITY brand (Diode Dynamics) and a great price. Only $390 for the pair (Take 10% off using coupon code JKFORUM at our website)
Available with a chrome bezel OR a black bezel.
These are DOT Approved and a direct fit using standard factory brackets. They even have an anti-flicker module built right in (which any newer Jeep guy knows has always been one of those hassles with LED upgrades).
You get H4 and H13 connections so it's plug and play.
They have integrated dual projector lenses that distributes the light in a WIDE, EVEN pattern for the low beam (that means NO blinding oncoming drivers). Side mounted reflectors provide an INTENSE light for the high beam.
These are DOT and SAE compliant.
Order yours now. Only $390 (take off 10% off on top of that with promo code JKFORUM at our site)
Available here: DOT 7" Headlight (Pair) - 4x4TruckLEDs.com
Don't want to spend the cash on these AWESOME lights? No problem we have you covered. Check out our XHP Series LED Conversion Kits. Plug and play for all makes/models. Our XHP series LED Bulbs are top of the line and DO NOT blind oncoming drivers like cheaper kits. They give you a better cut-off then any other LED Conversion Kit on the market.
Check out the XHP Kits here: XHP Series (6000 Lumen) CREE LED Headlight Conversion Kit - 4x4TruckLEDs.com
And yes, you get 10% off with coupon code JKFORUM on those as well (the code is SITE WIDE, so check out the LED Light Bars and brackets for your JK while you are there)
Former Vendor
No... why would they be heated? Well I guess I see why you'd want that but no. No added heat (it would lesson the life of the LED bulbs if you added heat)
Oh, driving in snow and ice, that kind of thing. Since LED headlights generate so little heat, many cheaper designs have a tendency to frost, freeze, or snow over when driving in severe inclement weather. Kinda hard to see at night with two inches of snow and ice frozen to your headlights, something that does not happen to traditional incandescent or HID headlights. But hey, they do look really cool.
Former Vendor
Yeah I get what you are saying. These are not cheap quality. Diode Dynamics makes some good stuff. Similar to the JW speaker lights everybody uses, they came out with their own version. They've been working on these for a while to get them perfect. SAE/DOT approved as well, so that means they pass the tests for vehicles.
