The perfect upgrade for your Jeep Wrangler JK D30 or D44 (Rubicon) front housing!
Old 11-06-2015, 08:30 AM
Former Vendor
REBEL OFF ROAD's Avatar
Default The perfect upgrade for your Jeep Wrangler JK D30 or D44 (Rubicon) front housing!
BUNDLE: Inner Axle Sleeves / Knuckle Gussets / Control Arm Skids
Rebel Off Road JK Dana 30/44 Lower Control Arm Skid Plate
Designed to be welded on the front Jeep JK lower control arm mounts. Protects your control arm joints from rock damage. Brackets are laser cut and CNC bent from 1/4" high strength carbon steel Heavy duty 3 sided construction provides for a VERY rigid bracket. Sold in pairs
The Teraflex JK Axle Sleeve Kit was created as a way to reinforce the weak factory axle tubing. The sleeves are designed to slide inside the factory tubes and provide increased durability and support throughout the axle. This prevents unwanted bending or breaking under extreme conditions. Sleeves must be welded into the housing.
Rebel Off Road Jeep JK Front Dana 30/44 Inner C Gusset Kit:
Rebel Off Road Jeep JK Dana 30/44 Inner C Upper & Lower Gusset Kit.
Designed to be welded to the front C-Yokes of the Jeep JK Dana 30 or 44 axle.
Brackets are laser cut and CNC bent from 1/4" high strength carbon steel.
1 Kit will fit a complete front axle.
(2) Upper Gussets for Stock 2.5" OD Axle Tube
(2) Lower Gussets for Stock 2.5" OD Axle Tube
Requires welding.
Purchase Item: http://jeep.rebeloffroad.com/product...-gust-skid.htm
Quick Reply: The perfect upgrade for your Jeep Wrangler JK D30 or D44 (Rubicon) front housing!
