Poison Spyder JK Body Mounted Tire Carrier
Former Member
Poison Spyder's JK Body Mounted Tire Carrier works with the stock rear bumper or just about any aftermarket rear bumper, and can accomodate up to a 40" spare tire and accessories. The main tire carrier assembly is made of 1-1/2" DOM tubing for strength and great looks. All of the plate steel components are CNC laser cut and brake-formed from 1/8" or 3/16" steel plate. The hinge and latch assemblies are designed to address common issues inherent in similar tire carriers from other manufacturers. The tire carrier comes with mounting points to add several Roto-Pax™ fluid packs as well as a Hi-Lift™ jack.
Here's a video showing features and benefits of the tire carrier:
https://www.youtube.com/watch?v=b_7tbiIDvJg Here's a video of the installation process:
https://www.youtube.com/watch?v=1Iy086zk4A8 Or you can Download the Installation Instructions (link to PDF file)
With a 40" tire:
Threaded mount, alignment cone and wing nut tire mount:
Detail of the internal bracing that helps strengthen the tire carrier mounting, rather than just bolting it to the exterior sheet metal:
Close-up of the adjustment cam on the hinge side:
See our website (link) for all of the info about the Poison Spyder JK Body Mounted Tire Carrier, or inquire through any of our Authorized Poison Spyder Dealers!
Former Member
Former Member
On another note; I'll be up at the shop this afternoon picking mine up, so maybe we can talk more about. Plus I've got a request from Frank (sm_rubi) to relay to you.
