Poison Spyder JK Body Mounted Tire Carrier
#21
Would you be able to tell me the total weight of the carrier? My jeep is already heavy with all the mods but I like the idea and the look of this carrier. My current bumper mounted carrier is about to die.
#22
Former Member
The shipping weight is 74 lbs. That includes about 4-5 lbs. of box and packing material.
#23
I have this tire carrier and must say I really like it but did run into a couple issues installing it. The plate that goes behind the driver 1/4 panel would not fit for the life of me and had to be cut down about an inch to get the bolts to line up or for it to even sit flush to 1/4 panel. The other is the aluminum spacer that is suppose to go on to the latching mechanism would not go on, it is ever so slightly too small in diameter and works just fine without the spacer. All in all I'm stoked with the carrier and like that I can still mount RotoX packs to it. My question is what needs to be bought for the HiLift to be mounted?
#24
I must say I really like this tire carrier. It solves some concerns I had with the GenRight design. But I don't like how the HiLife is mounted, the long downside overhang could be a vulnerable point.
[QUOTE=DTS;4041403]We're starting to see some customer-installed photos of these JK Body Mounted Tire Carriers now...
#26
Rumor has it they are working on different ways to mount the hi lift. But till it's from their mouth who knows. I'm still waiting on mine to get delivered.
#27
Former Member
Probably, but not without some extra work. I think the EVO corners are flat vertically. The latch plate of our carrier is curved to fit the slight vertical curve of the Jeep's tub. It fits our corners because they are also curved. But the ones that are flat (EVO, River Raider, etc.) would be a problem. One work-around I can think of would be to cut a rectangular notch out of the plate of the EVO corner to let the latch plate seat right against the body. But you'd lose the extra strength you would have gained if it was bolted through the corner itself.
#29
Former Member
#30
I know you've mentioned before that this isn't designed for hard core use, but I want to know if I can safely mount TWO 4 gallon rotopax containers in the rear or vertically on the left side and not be over stressing the carrier.... I do moderate wheeling, occasional crawling but nothing that I'd consider hard core... I'm more concerned about how it'll hold up to weight with 100's of miles of wash board roads.... Would you recommend a bumper swing out instead??
