Poison Spyder JK Crusher Corners
Former Member
Hey guys we have some great news to report on our JK Crusher Corners. First the big news:
They're now ONLY $399!!
Yeah you read that right. Now only $399, down from the old retail price of $605. Why the huge price drop? Simply put, they're now less expensive to us, so we're passing the savings on to you. We're a pretty well equipped manufacturing shop, but these corners are die-formed in a huge stamping press, which we simply don't have the equipment to do ourselves, so we've always used an outside source for the stamped blanks. We recently switched suppliers (yes, they are still MADE IN U.S.A.), and the price came down dramatically. Helping that was that its now a one-piece part for the 4-door Crusher Corner (we used to have to weld 2 pieces together), saving some expense in welding and finishing.
There are two other minor differences in these new Crusher Corners versus the old ones: First, they no longer have the Spyder logo cut out at the forward edge. Second, we made the cut-out around the tailgate hinge openings in the passenger side piece larger, so that our JK Body Mounted Tire Carrier can be installed without any further grinding or modifying of the Crusher Corners. For those not running the Body Mounted Tire Carrier, you would simply keep the stock plastic hinge bezels (the old Crusher Corners required them to be removed). Other than that, they're the same form-fitting, fit-like-a-glove, 1/8" steel armor that they've always been, just at a price that is now over $200 LOWER!
We've also added a new configuration, for those who would like to install Crusher Corners but retain the stock taillights. So now there are four configurations:
JK 4-Dr Crusher Corners - LED Taillights
JK 4-Dr Crusher Corners - LED Tail & Backup Lights
JK 4-Dr Crusher Corners - OEM Taillights
JK 4-Dr Crusher Corners - Blank (no taillight cut-outs)
(Note that 2-door Crusher Corners are also being reconfigured. They're currently unavailable since we're still working on a tooling solution for them. Ironically, 2-door corners are actually bigger than 4-door corners, exceeding the capacity of the machinery we're using on these, so we might still have to make them as a 2-piece assembly, but we're still working that out with the die-makers. We'll report when we have news on the 2-door version.)
NEW LED LIGHT & WIRING BUNDLES!
In addition to huge price drop on the new Crusher Corners, we've also taken steps to make the conversion to LED taillights and/or backup lights a lot more affordable. You may remember last year we introduced a brand new plug-and-play LED taillight wiring harness system, which made it possible to install our LED taillights, reverse lights, and license plate/3rd brake light, all without cutting your Jeep's wiring harness or splicing any wires. You simply plug it in to the stock taillight connectors! Well, we've bundled up everything you need to install either LED Taillights or LED Tail & Backup Lights, for one new LOW PRICE! You can now save over $100 on one of these kits, compared to purchasing the components separately at MSRP. The result: with these new low prices you can now get the Crusher Corners and everything you need to convert to LED's, for less than the old price of just the Crusher Corners!
JK LED Tail & Reverse Lights with Wiring Harnesses Kit - $199
JK LED Taillights & Wiring Harnesses Kit - $149
Former Member
Former Member
The 5-axis laser that's used to cut these out of the stamped blanks isn't high enough resolution to do the fine details of the Spyder logo. We were able to do it on the old ones because they were a two-piece assembly, which we cut out the forward pieces here on our own flat bed laser, then welded them together.
