Switch-Pros now available at Inspired-Engineering!
Former Vendor
We are proud to announce we now carry the Switch Pros SP-8100 switch panel kit.
These are universal so will work on any model, CJ, YJ, TJ, JK included.
Here are some quick specs on the product.
PRODUCT DESCRIPTION
Eight user-programmable switches
User-selectable switch legends
Illuminated switches with user-adjustable brightness
Programming and control via panel or smart phone
Bluetooth interface
100A solid state power module, engine compartment rated
Automatic shutdown for overcurrent and low voltage
Programming options are: On/Off or Momentary, Ign. or Batt., Flash and Strobe functions, Low Voltage Disconnect, and Switch Memory
Plug and play installation
Switch Panel Specs:
4”L x 2”W x .5”H (excluding tabs)
Enclosure: Anodized Aluminum
Orange LED switch indicators
Green backlighting
4’ interface cable
Power Module Specs:
6”L x 3”W x .5”H (excluding connectors)
Enclosure: Anodized aluminum
8 Outputs, 7 rated @ 18A, 1 rated @ 30A
100A maximum rating 125°C to -40°C
16-pin, sealed automotive connector, wire harness w/100A fused power cable,
light and ignition input wires, and eight 3’long output wires
Switches can be programmed to be: On/Off or Momentary, ignition or battery powered, flash, strobe, low voltage disconnect, and memorize previous settings. There is also a programming function to adjust the brightness of backlighting and indicator LEDs.
PM us for special pricing, and more info!
PRODUCT DESCRIPTION
Bluetooth interface
Switch Panel Specs:
Green backlighting
4’ interface cable
Power Module Specs:
