TeraFlex 2.5" Coil Lifts for 2007+ JK's
Old 07-23-2014, 10:33 AM
Sponsoring Manufacturer
TeraFlex's Avatar
Default TeraFlex 2.5" Coil Lifts for 2007+ JK's
TeraFlex Suspension offers 3 different configurations of our popular 2.5" Coil Lift series. These kits will allow you to run up to a 35” tire (aftermarket wheels with 4.5” backspacing or less are required).
Note: 2012+ JKs may require exhaust spacers (#2610000) or other exhaust modification for proper driveshaft clearance if front extended shock length is greater than 24.5”.
#1251000/#1251002
The more complete configuration (#1251000/#1251002) includes a set front and rear set of TeraFlex 9550 shocks and a rear axle mounted trackbar bracket.
Attachment 1
#1352002/#1352000
Our mid level 2.5" coil kits (#1352000/#1352002) uses front and rear shock extensions that allow the stock shocks to be reused. It also has the rear drop frame trackbar bracket.
Attachment 1
#1351002/#1351000
The basic lifts (#1351000/#1351002) includes all of the essential items needed (some form of shock modification will be required- either adapters or new longer shocks). A rear trackbar bracket that is mounted at the frame is included.
JK 4 Door
JK 2.5” Lift Kit w/ 9550 Shocks 1251000 $768.99
JK 2.5” Lift Kit w/ Shock Extensions - No Shocks 1352000 $524.99
JK 2.5” Lift Kit - No Shocks 1351000 $504.99
Install Time: 4 hours
JK 2 Door
JK 2.5” Lift Kit w/ 9550 Shocks 1251002 $768.99
JK 2.5” Lift Kit w/ Shock Extensions - No Shocks 1352002 $524.99
JK 2.5” Lift Kit - No Shocks 1351002 $504.99
https://www.youtube.com/watch?v=2OMiDrSaoSk https://www.youtube.com/watch?v=vz-R5E-NPQg Please contact your favorite TeraFlex dealer to make your purchase.
Old 09-03-2014, 05:57 AM
bmaloy32's Avatar
Default Mid Level Lift
Interested in the mid level lift... I'm currently stationed in Korea and wondering if shipping to an APO is an option.
Thanks,
Brandon
Old 09-03-2014, 12:35 PM
TeraFlex's Avatar
Thanks,
Brandon
Check with one of dealers here, there are several that will ship to an APO.
Quick Reply: TeraFlex 2.5" Coil Lifts for 2007+ JK's
