Winter is coming again, tire storage reminder
Old 10-04-2007, 07:50 AM
Sponsoring Vendor
Discount Tire's Avatar
Default Winter is coming again, tire storage reminder
I know this won't apply to your Jeeps but its good info none the less. A lot of you have more than one car. If any of you are running Track Tires or Drag radials such as the Nitto 555R, the 555RII, Nitto NT01's of similar ultra performance track or RT tires (Falken 615, BFG drags etc.). Nitto Suggest you take them off for the winter if you live in a climate where temperatures drop below 32 degrees. They recommend storing them indoors at a temperature above 32 degrees and at 1/2 the normal running pressure. Drag radials and RT Tires are prone to cracking at freezing temperatures if this occurs have the tire inspected immediately. Attached is a picture of a tire that has cracked due to improper storage at cold temperatures. Here's looking out. Oh and BTW our winter tire stock is in. www.discounttiredirect.com
Quick Reply: Winter is coming again, tire storage reminder
