JD Squared, Inc. MAD Series Cutting Tables
Old 01-18-2017, 06:42 AM
Former Vendor
JDSquaredInc's Avatar
Default JD Squared, Inc. MAD Series Cutting Tables
JD2 MAD Series Plasma Tables
Sizes: 4x4 - 4x8 - 5x10
MAD 4x4 - List $15,950 / Factory Direct $12,950
MAD 4x8 - List $18,950 / Factory Direct $15,950
MAD 5x10 - List $21,950 / Factory Direct $18,950
Overview Video: https://www.youtube.com/watch?v=jIWc-PS_k5I Features:
- Welded base is made of 3/16" steel plate construction.
- Base is supported by 4" x 3" x 1/4" wall steel legs with 30mm leveling pads.
- Adjustable slat height adjustment and slat configuration.
- Beams (Y-Beams) are made out of 4" x 3" Box tubing 1/4" wall and machined in a twist-neutral jig.
- 3/4", 16 pitch spur gear on the Y-Beam provides precise alignment.
- The spur gear is driven by a 10:1 high precision gear box.
- The Gear Box is driven by a USA made Brushless Servo Motor.
- Rapid speeds 1,000+ inches per minute.
- Rollers have an 8,900 lb. capacity with a dual-row radial ball bearing which carries the 300 lb. Y-Carriage and Gantry setup.
- The gantry is an Aluminum structure with precision machined weldments. Complex milling processes ensure that the gantry has perfect angles, flat surfaces, and holds the spur gear perfectly vertical.
- The Z-axis rides on a 25mm linear guide
- Magnetic break away to ensure the system powers off when the torch is disengaged.
- Switches provide Initial Height Testing and a Z-Homing Process to ensure accuracy.
- Computer included (Computer, Mouse, and Keyboard)
- Table ships fully assembled and tested.
* Plasma Unit not Included with MAD Series Cutting Tables.
Please send a message or email Sales@JD2.com to get a shipping quote. Thanks!
Old 01-18-2017, 03:59 PM
Former Vendor
MAD Series test cut on 3/8" plate cut at 65 amps.
Old 01-23-2017, 01:36 PM
Former Vendor
We have been doing some test cutting on 1/4" Aluminum using both Air and Nitrogen.
JD Squared, Inc. - MAD Series Plasma Tables
Quick Reply: JD Squared, Inc. MAD Series Cutting Tables
