Check engine light on again..Same code-Just came back from the dealer. Need help!
A few weeks ago I had code 0456 come up...Cleared it 3 times with the code reader and the check engine light kept coming on. Took it to the dealer last week and they said a "sensor" had to be replaced and that it was fixed..
Well of course, again yesterday the check engine light comes on again and its the same code..
The code reads as this: small leack in the evap system...
I know people have mentioned the gas cap being off. I've reset this code again and it came back on. Gas cap is on and fine...
What could be causing this?
I cleaned the throttle body a month ago..Would that have anything to do with it?
Any help would be appreciated
What year? Is it still under warranty? Take it back to the dealer that said it was fixed and point out that it was not fixed. Check all your vacuum lines for a small leak.
Went back to the dealer again yesterday since it came back up. They said no leak was detected again and that they cleared the code. Brought it home last night, parked it and this morning when I turned the Jeep on, it came back on again.
What gives? If there isn't a problem why is this still popping up? This will be the third time it would go back to the dealer for this issue and they said there is nothing wrong.
Originally Posted by bob-o
Did u Check to see if the plug was connected on the evap canister cuz I put on my evap skid the other day and drove around town for a bit and the same code popped up. Crawled under the Jeep and noticed that the plug wasn't fully connected.
Originally Posted by jdk
If it continues make the dealer do a smoke test on the fuel evap system. That should find any problems in the system.
They said when I called this morning to bring it back "so they can keep it until they figure out the problem". Seriously?
Where would this be located by? Figured if it was at the dealer twice in a week that this would have been looked at
