'07 Soft Top Side Windows on '14 Soft Top?
Will the side windows from an '07 factory soft top fit on my '14 factory top? Looking to get some trail windows that I won't care how much they get scratched.
Don't know exactly, but they changed the size of the rear window. Maybe in 2010?!
Have read a thread on a german forum where someone had trouble with top and windows from different model years.
I think he had newer side panels and the older rear window which resulted in 2" gaps on either side.
If your setup would fit, it would be more of a loose fit I think.
He had a 2013 top with the window set from an older model. According to him he only had issues with the rear window while the sides fit perfectly.
So I assume the side windows are interchangeable through the model years, but I hope someone with first-hand experience will chime in.
Don't know about the pricing.
Have checked the mentioned thread again.
I can only assume the same holds true for the 4dr, but no first hand experience.
Only the rear window got wider on the soft top.
On the hard top, both the rear AND sides were enlarged. This leads most folks to assume that the sides on the soft top were enlarged also. Easy to make that assumption, I made that assumption myself until I had both tops on hand.
Based upon pics I have seen, I have a high degree of confidence that the 4dr is the same way.
Once again, any year side will fit any year top on the 2dr. As stated, I have first hand experience putting a post 2011 side on a pre 2011 top, and vice versa.
The clear plastic area of the side windows did not appear to me to be any larger on the 2dr.
