Sponsored by:
Sponsored by: DashLynx
How do you Rotate 5 tires
Old 03-31-2008, 01:09 PM
sgtsasquatch's Avatar
Default How do you Rotate 5 tires
How do you all go about putting your spare tire into the rotation?
Old 03-31-2008, 01:10 PM
Henri's Avatar
It's up to you but you don't need to include the spare on the rotation. As far as I know front ones go in the back and back ones upfront. When I rotate mine I leave the spare alone.
Old 03-31-2008, 01:36 PM
I want to extend the life of my tires by rotating the 5th one in, thats my reasoning behind it.
Old 03-31-2008, 01:45 PM
RedneckJeep's Avatar
Read the owner's manual. USUALLY, it's RR in spare, Spare on RF, RF to RR, LF to LR and LR to LF.
Old 03-31-2008, 01:51 PM
pkdailey4's Avatar
Redneck's absolutely correct on that ! And rotating all 5 gives you 20% less tire wear. Its not just a decoration for the tail gate !
Old 03-31-2008, 02:29 PM
I just bought a set of 35's and on a military pay check and a wife that doesn't understand the finer things in life I need these to last. Thanks for the help.
Old 03-31-2008, 04:41 PM
Suffolk JK's Avatar
Originally Posted by itsokitsgot4wd
Have you seen how cheap tires are for these? there less than 120 bucks
For a small pizza cutter street tire. Not for quality, bigger, mud terrains.
Old 03-31-2008, 05:10 PM
Red Rubicon's Avatar
I put my spare into rotation too. I put my spare into rotation becuase I don't want 1 new tire and 4 very well worn tires. If I chose to get other brand tires, I have a mismatch issue. (Or, a flat at 40k miles, I got an issue.)
Here's how I did it:
Spare to RR
RR to RF
LR to LF
LF to Spare
Putting the spare on the drive wheel was my logic for choosing RR.
It's your jeep, you make the payments, you do as you see fit.
Old 03-31-2008, 05:29 PM
Black08X's Avatar
Spare to RR
RR to RF
LR to LF
LF to Spare
Just for clarification, I'm assuming you swapped the RF and LR?
Old 03-31-2008, 05:34 PM
Geeper4x4's Avatar
Several have written exactly the way I do it as well. Sometimes a picture makes more sense. The one on the right for 4WD is the way I explain it.
REARWARD CROSS (G)
Quick Reply: How do you Rotate 5 tires
