P2308 code and running rough???
Old 10-30-2013, 04:09 PM
ytee's Avatar
Default P2308 code and running rough???
Engine started running rough today and checked for a code and it was P2308 ignition coil c secondary circuit. Does this mean that the coil is bad?
Old 10-30-2013, 04:29 PM
ronjenx's Avatar
Not necessarily a bad coil.
P2308-IGNITION COIL 3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
  • Set Condition: If PCM detects that the secondary ignition burn time is incorrect, too short, or not present, an error is detected. One Trip Fault. Three good trips to turn off the MIL.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ASD OUTPUT CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]COIL CONTROL 3 CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]COIL CONTROL 3 CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
Quick Reply: P2308 code and running rough???
