2012 Jeep JKU Sahara rough idle and vibrations
2012 Jeep Wrangler Unlimited with 14400Km on the odometer. Today, when at a red light, the vehicle vibrates so hard, I can feel it on the seat, floor and steering wheel. It also does it when cruising at low RPM under slight load. (pressing the accelerator slightly)
Anyone have any idea or suggestions? I could also take it in to the dealer but I feel you guys probably know a lot too.
thanks
thanks
let me know what you guys think
I noticed a similar vibration on my 2012 Rubi. It was idling in my garage earlier this week and all of the sudden it started running rough and loud for several seconds. I also notice a significantly increased vibration just after starting from a complete start under low to moderate acceleration.
I'm just about to hit 3000 miles, and will probably take it in next week to use a free oil change coupon from the dealer. Will have them look at it then.
I have the same issue, it's happened twice. I'm definitely interested in more information about this. First one was at less than 1000 miles, second was just under 2000 miles on the clock.
I the meantime, if you guys can get me a water pump, I would gladly install it myself. Thanks
update: Not the water pump
I brought it to the dealer to diagnose. They had a TSB on this problem description. TSB says: remove serpentine belt and test for vibration. If vibration is gone, check water pump. I have a bad water pump. No big deal you say? No parts available to service my JK. 2012 JK grounded for 3 weeks because Chrysler has no parts to service it. I escalated it to Chrysler Canada who is looking into it.
The dealer replaced the water pump. That didn't fix it. Now they are tearing into my brand new Jeep JKU trying to source the root cause. Chrysler Engineers are feeding them clues, but after a week now, the JK vibrates on.
They have checked everything from water pump, pulley, steering pump...everything attached to the serpentine belt. They replaced one of the engine mounts...with no avail.
Is was the transmission mount.
thank you everyone for your input. I am sharing the resolution with all in the hopes to avoid the trouble I had. Further to that, Chrysler Canada stepped up to the plate and paid for a rental. Kudos to Chrysler.
