Is 4.10 always better than 3.73 in a jkr?
I traded a Willys with 3.73 for a Rubicon with 4.10 both on 35s and absolutely noticed the difference. The 4.10 is still a little under powered with 35s but much easier to deal with day to day. If you have the choice the 4.10 should be your choice.
I was referring to the 3.6.. Looking at a 2 door rubicon, the 4.10's are a little harder to find. was thinking that if didn't need the super low crawl speed, i.e. No rocks that maybe a 3.73 would actually be better. But with 90% street and highway the 4.10 with 35" would be the better option
Definitely a combo of the two. Not very noticeable in crawl between 4.10 and 3.73 (assuming both vehicles have a 4:1 Rubi transfer case) but on the highway with 35s very noticeable.
In what way? I currently have a JKR with 4.10, but possibly purchasing a JKUR with 3.73
This might be useful to you... It'll tell you what you have for your overall gear and you can then compare.
When you're in 2WD, the transfer case ratio is 1:1 bot a Rubicon or a regular wrangler (or 4HI for that matter)
When you're in 4LO, the TC ratio for a Rubicon is 4:1 and the Wrangler is 2.72:1
For the transmission, look up the gear ratios for your year and then use 1st gear for 4LO and your highest gear for 2WD
Keeping all things equal, change the diff ratio and you'll see what it does to RPM and at a specific MPH.1
4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
All that said if you plan to stick with stock tires the 3.73 will be fine.
More grunt when taking off from a stop, more torque at highway speeds and overall better power from the motor. 4.10 isn't perfect as I would much rather have 4.88 with 35s but much more bearable day to day. If you have a choice take the 4.10. Just order what you want rather than settle for dealer inventory. All that said if you plan to stick with stock tires the 3.73 will be fine.
Thanks. I already own the 4.10, but it's on a 2 door and we've been eyeing going back to a 4 door. There's a used rubicon near me for a decent price but it's in immaculate shape, but it's 3.73... I think I'd rather have a great shape used rubicon vs a lower model, that's where I'm at now price is a huge factor.
