4x4 failure on snow, car stuck.
#21
Well, idid't hear anything beside the struglle noise of the car tryng to get out.
The 4H has working, i feel it al that day and even before i got stuck, that s no question about it.
The shaft must be collapsed when i try to get out.
I will look forward on the Eton differentialls too, i want to know any thoughts and insides over the lockers (electricall or air), over theire compared reliabillity, prerformance and cost.
I really think now that a locking capabillity will prevent a shaft break in similar condition.
#22
Having run the Detroit TruTrac Limited Slip previously.... and a ARB locker up front; the LS has better road manners and would probably work better with the onboard computer controlled Brake Lock differential system.
#23
You were particullary satsified over the ARB locker?It is reliable?
I also want to lift it but don't want to compromise the Jeep stability over the highway at all, or at minimum as possibile.
Any reccomandation on this too?
A 1,75 -2 inch lift kit will do the dew?
#24
As mentioned installing lockers is not gonna prevent you from breaking axle shafts (and its called axle shaft, or half shaft, not propeller shaft) Avoid giving too much gas while the wheels are fully turned. Sudden traction while the wheels spin can snap axle shafts in a hurry. Avoid hopping when you loose traction.
I learned the hard way on my other JKU......and I had lockers then too.
8
8
#25
Other's say they never belive that the shaft could broke on snow tranction, but that's was the case.
It collapsed, it is iron after all and you never know when it breaks.
I keep receiving nice feedbacks about the Eaton Detroit Truetrack's so i guess i ll stick with one of them.
To save the driveablility for on road driving also i think to lift the Jeep max. 2 inches, i founded a polyurethan kit with longer isulator extenders and bump stopers but it does not include any shock extenders or longer swaybar links.
My question for you, all the Jeep's guru outhere...Are the shock extenders and longer swaybar links a must, or i can lift it withouth them with no problem?
Thank you again everybody for the great support.
#26
Other's say they never belive that the shaft could broke on snow tranction, but that's was the case. It collapsed, it is iron after all and you never know when it breaks. I keep receiving nice feedbacks about the Eaton Detroit Truetrack's so i guess i ll stick with one of them. To save the driveablility for on road driving also i think to lift the Jeep max. 2 inches, i founded a polyurethan kit with longer isulator extenders and bump stopers but it does not include any shock extenders or longer swaybar links. My question for you, all the Jeep's guru outhere...Are the shock extenders and longer swaybar links a must, or i can lift it withouth them with no problem? Thank you again everybody for the great support.
#27
Just to make sure now, are you suggesting to buy the longer rear links and to install the old one on the front?
Also please also give me some feedback..how it feels in terms of driveability, especially in corners and in relatively quick high speed turns..on roads..highways..is there a difference before and after?
Cheers
#30
