Any difference Platinum P-1 Size 34 and Platnum P4 Size 34/78DT
Results 1 to 4 of 4
  1. #1
    JK Freak kingteddybear's Avatar
    Join Date
    Nov 2009
    Location
    Beaumont, TX
    Posts
    767
    Question Any difference Platinum P-1 Size 34 and Platnum P4 Size 34/78DT
    Any difference between the DieHard Platinum P-1 Group Size 34 and Platnum P-4 Group Size 34/78DT beside the dual terminals on the latter? Both state 880 CCA and 135 minutes reserve capacity.
    Thanks,
    2010 Wrangler Unlimited Sport Flame Red
    Auto, 3.73 w/ Trac-Lok, Freedom Top
    Cibie 7" H4 headlights w/ Osram 70/65 bulb
    MBRP Exhaust #S5502409
    Harley Davidson mirrors for doors off
    RR XHD w/ Prerunner bar
    Warn M8000
    RR XHD w/ Tire Carrier
    RR RRC Side Armor rails
    Pioneer DEH-P6200BT head unit & GEX-P920XM XM sat tuner
    Polk Audio db6501 & db651s speakers
    JL Audio PowerWedge PWM110-WX sub
    LubeLocker Gaskets
    Drake Hood Latches
    Tuffy Security Drawer
  2. #2
    JK Super Freak Lorrel's Avatar
    Join Date
    Apr 2007
    Location
    Lancaster Pa
    Posts
    1,694
    Quote Originally Posted by kingteddybear View Post
    Thanks,
    Funny you should ask, as I just made a post here:
    http://www.jk-forum.com/showthread.p...ttery-good-for
    The P-1 has a height of 7 4/5" width of 6 4/5" and a length of 10 9/10".
    The p-4 has a height of 7 4/5" width of 7 1/10" and lenght of 10 9/10".
    Either should fit in the JK.
    "And with one Voice, the People may express the grateful feelings of their hearts, and consecrate themselves to the service of their Divine Benefactor, to afford His blessing on the Governments of these States respectively, and prosper the public council of the whole with that Wisdom and Fortitude which may render them fit Instruments, under the Providence of Almighty God, to secure for these United States, the greatest of all human blessings, Independence and Peace."
    www.pafoa.org
  3. #3
    Join Date
    Nov 2009
    Location
    Beaumont, TX
    Posts
    767
    Quote Originally Posted by Lorrel View Post
    Saw your post in that thread right after submitting my post. Judging by the dimensions you supplied it appears the 3/10" difference in width accounts for the side terminals. I was thinking of using the side terminals to power a new fuse / relay block used strictly for accessories but looking over the reviews on the Sear's site it looks like they may be a weak leak. There were a lot of complaints about the side terminals failing. One or the other side terminal would fail but the battery if tested through the post would test good. Very few complaints about the battery itself just the serviceability of the side terminals on the P-4 Group Size 34/78DT. Indeed the P-1 Group Size 34 carries a higher customer rating and it appears it is due to the lack of side terminals.
    Warn M8000
    LubeLocker Gaskets
    Drake Hood Latches
  4. #4
    Join Date
    Apr 2007
    Location
    Lancaster Pa
    Posts
    1,694
    Yea I agree with the side terminals. They are a good thing to have if you're running some aux equipment such as extra lighting or a mid range power amplifier, and should not be used for heavy duty equipment since the terminals are only about 5/16". The key to good battery connections is a tight fit. Some have cranked down on the side terminals and cracked them internally. Although the AGM battery will not leak, having a loose connection or one that has a crack is a sure sign you'll get a heat build up which could result in premature failure.
    www.pafoa.org
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
