Average alignment cost
I couldn't find anything on here on the average cost for an alignment. I know for my previous car *bmw* the dealer would charge me $250. Does anyone know how much it typically runs?
I paid $179 for lifetime alignments at firestone complete autocare. So whenever I need an alignment I can go back and they redo it for no charge, that's going to come in real handy since It needs to go back as I change suspension stuff up.
that's a sweet deal. Can yo get this done even if you move from the area? Do other Firestones cover the work?
not a whole lot that can be adjusted unless you have adjustable control arms or a cam bolt kit (most recommend against these) other then toe-in. I am guessing unless it is an actual 4x4 shop they would not mess with your adjustable control arms anyway.
- Toe
- Steering Wheel Centering
Both of these can be adjusted in your driveway in about 15 minutes with a couple basic hand tools and a measuring tape. Here is the procedure on how to do that:
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Ignore the other procedures there because you've not replaced those OEM parts with adjustable components (assuming your profile is complete). If you take it to an alignment shop, they will give you a printout with a whole bunch of numbers that they cannot change unless you wish to add mods to your Jeep. It's a waste of money to ever use an alignment shop unless you have reason to suspect that you actually bent something and may need some (likely major and expensive) repair work, and you need that printout to tell help determine what is bent.
My local Big O charges $25 to put it on the rack and hand me a read out which is all I want. Like Mark says, there isn't much to it but if you do have adjustable arms, the initial alignment will give you a datum to go by for caster angle. Once you know what it actually is via the alignment readout, then it's just a matter of using your angle finder to make caster adjustments from there on your own.
Just don't get large tires.... I live in the motor city and have found only two shops that can handle 37s. Only one could handle 37s on beadlocks. Total pain in the butt.
Agree that normally an alignment is $90-$100. As noted above, cool shops will give you a readout or a small fee. I'd still have them adjust it on the rack. My tie rod sees a lot of abuse and I'd love to pay $25 to find out if my toe is out once in a while.
