Best tires for ice?
#21
If it's truly "ice" and not sleet or icy snow, I'd just stay home. It seems like when they get those storms in the southeast, since the locals really don't have the equipment to deal with treating the roads it'll be too treacherous especially if you're not used to driving in it, not to mention the other idiots on the road. 4wd will help on the ice, but stopping will still be impossible.
For snow it seems people love their Duratracs. I have MtrK's. not the best but my Jeep is built more for off-road.
#22
... It seems like when they get those storms in the southeast, since the locals really don't have the equipment to deal with treating the roads it'll be too treacherous especially if you're not used to driving in it, not to mention the other idiots on the road. 4wd will help on the ice, but stopping will still be impossible...
#23
That's what I remember is that I thought they had outlawed chains awhile back due to tearing up the roads and safety reasons. However, I was in a recent similar discussion and found this website.
https://www.thebalance.com/chain-laws-by-state-1361486
So it seems that chains are legal, as long they don't come in contact with the road surface.
#24
Rarely, but yes. That's one of the reasons I like having some extra wheel-well clearance, to fit chains if needed. There have been a few times that chaining up all four tires was the only way I was going anywhere (think: solid ice sheet for a road). Up here (in Oregon), you are required to carry chains even with a four-wheel drive, and they sometimes require all vehicles to chain up, regardless.
#26
I know chains can't be beat in some cases, but I go with the severe snow rated tires.
#27
AutoSocks
Buy two pairs of AotoSocks. They are easy to install and remove when needed. Throw them in the washer when you get home and they are ready for the next go. They get me up my steep drive in the worst of conditions!
AutoSock - The Original Norwegian Snow Socks For Vehicles
I use them on my Rubicon since Jeep says you cannot use chains.
I have GY Duratracks installed.
#28
- It has an unloaded weight of 6,500 pounds or less;
- It is operated to provide power to both the front and rear wheels;
- It is carrying chains;
- It has mud and snow, all-weather radial, or traction tires on all of its wheels;
- It is not towing another vehicle;
- It is not being operated in a manner or under conditions that cause the vehicle to lose traction.
Not sure about Washington, I probably should check since I'm heading there soon.
#29
Well, yes and no. In Oregon, a four-wheel or all-wheel drive passenger vehicle is exempt or partially exempt from the Chain Law if ALL of the following statements are true:
Traction Tires, as defined at https://www.tripcheck.com/Pages/traction-tires.asp include tires with the severe snow rating and studded tires. According to minimum chain requirements: https://www.tripcheck.com/Pages/mini...quirements.asp
In typical winter conditions, vehicles rated at 10,000 pounds gross vehicle weight (GVW) or less and not towing or being towed are allowed to use traction tires in place of chains. For traction tire information go to Traction Tires.
#30
Having nothing better to do right now, I went back and re-read everything on TripCheck and did a little more digging. Seems that we aren't the only ones having this discussion; there is a lot of mixed information out there on this exact question.
So I sent an email to ODOT, and I specifically asked them:
"If a 4WD or AWD has "traction tires" (as defined on TripCheck) on all of it's wheels, does that vehicle really still need to be CARRYING chains in order to be exempt?"
They replied today:
"Thank you for contacting AskODOT at the Oregon Department of Transportation's (ODOT).
Yes, an All Wheel or Four Wheel drive vehicle may be exempt from having to put chains on in typical winter conditions and do have to meet all six requirements below:
Exemption #2
Yes, you would be required to carry chains even if you had traction tires on all four wheels."
Exemption #2
I suggested to them that they change the wording on TripCheck to state that although traction tires may be used in place of chains that you still need to carry chains.
Sounds like Washington is much the same, here's a good write-up on both WA and OR:
CHAINS REQUIRED might not mean chains ON
Anyway, thanks for giving me an excuse to research this again, it comes up every few years.
I'm not familiar with AutoSocks but I see they do meet the definition of "chains" in Oregon, if you have a vehicle that doesn't allow conventional chains or cables. My friends with Subaru's will like to know that.
I think we've officially turned this thread into a PNW Chain Law thread!
