Best tires for ice?
#31
#32
Here's what I just sent ODOT. Can't make the question any clearer.
Quoting ODOT at https://www.tripcheck.com/Pages/traction-tires.asp
"In typical winter conditions, vehicles rated at 10,000 pounds gross vehicle weight (GVW) or less and not towing or being towed are allowed to use traction tires in place of chains."
Is a vehicle specified above with traction tires legally required to also carry chains?
Please note that this is NOT a question regarding the exemption from chain requirements for 4WD vehicles under 6500 LBS that are carrying chains, etc.
This regards an internet discussion at https://www.jk-forum.com/forums/stoc...-339146/page3/
and I'll be posting your reply.
Thanks!
Thanks!
#33
ODOT called...
ODOT called me this morning. It was nice to speak with someone and get that instant feedback and clarification from an old fashioned conversation.
Bottom line is that under 10000 pounds with Traction Tires, chains are NOT required to be carried. And it does not matter whether the vehicle is 4WD or not.
She mentioned that their website needs to clarify this, and that Traction Tires have a specific definition -- Studded, Retractable Studded, and Severe Snow rated which are marked with a mountain/snowflake emblem on the sidewall. See https://www.tripcheck.com/Pages/traction-tires.asp
We also talked about the exemption for 4WD vehicles under 6500 LBS that are carrying chains, etc. That's a separate rule, and as soon as 4WD is mentioned people tend to immediately jump to that rule. Finally we talked about "conditional closures" in more severe situations where the requirements are set based on conditions.
#34
Here's your virtual beer!
I'd be reluctant at this point to call them again, for fear of getting a different answer.
Wow. OK. So they told you traction tires on any vehicle under 10000 GVW are good to go and do not need to also be carrying chains? Good to know!
Then I wonder when the "exemption rule" would apply. I guess that rule applies for a 4WD or AWD under 6500 lbs that has only M+S tires or all-terrains (but not "traction tires"), like my JK and so many other rigs on the road, would still need to be carrying chains. BUT... if it had actual traction tires all around, it wouldn't.
Makes a good argument in favor of those BFG KO2's (with the mountain snowflake rating) I've been thinking about! (In fact, I just put some mountain snowflake all-terrain's on my pickup, and the difference is very noticeable; plan to run them on that rig year-round.)
Maybe this inquiry will at least help push ODOT to get the website information updated. Maybe they should just remove the words "traction tires" from the exemption rule, since having traction tires make the rest of the rule irrelevant, it's redundant at that point.
#35
