"Bouncy" ride causes?
Ever since I switched to my new tires 305/75R16 Adventuro M/T, I have been getting a weird bouncing in my Jeep. The tires are all road force balanced. No warping in them either. However, between the speeds of 25(ish) and 45(ish) my Jeep does this weird bouncing thing. It's not rough at all. Doesn't jar you around, vibrate, or have any side to side motion. It's just a very gentle, soft and rhythmic bounce. It's weird because when I slow down or hit the gas the bounce slows or speeds up with the speed of the vehicle. However, right at around 45 and anything faster, like clockwork, the bounce goes away and it rides very smooth. Even on the highway at high speeds. Smooth. Really strange to me. Any ideas?
If it didn't do this before the new tires, I would suspect the tires.
Tire places like to sometimes inflate the tire to what's on the side wall, 45psi, etc
First thing I would check is tire pressure, I run mine at 32
You may have a bad spot in one of the tires but first things first, check tire pressure.
If that don't work I would go back and explain what is going on to the tire shop.
Have them check it out
I'm just gonna take them in and make the mechanics re-balance the tires, rotate them, and bring the pressure down a couple pounds. I still have a hair of tread left on the edges to add to my contact patch from the chalk test I did today. If none of that works them I'm just gonna live with it until they wear out.
40,000 miles in. Probably a little over half of those are straight highway miles. Been off-road 4 or 5 times, but nothing super crazy. No squeaking and they rebound pretty well. I have been on the prowl for the JKRU w/shocks setup to get a very mild lift and might have found a set. I've actually been hoping it is my shocks as that would fix it.
