Can I remove TPMS and just put normal valve stems on factory wheels?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Join Date
    Oct 2007
    Location
    Michigan
    Posts
    18
    Default Can I remove TPMS and just put normal valve stems on factory wheels?
    In the stock Sahara wheels, will standard rubber valve stems fit in the place of TPMS, or no?
    I put solid brass valve caps on the wheels. OVer the winter the brass reacted with the aluminum valve stems, and they became permenantly fused together. 2 valve stems broke off altogether when I tried to remove the caps, and the others have damaged threads.
    I want to get rid of the TPMS altogether.
    I really need to replace ONLY the aluminum valve stem on the TPMS, but no one (including Jeep) sells just that part, you have to buy the whole TPMS ($35 x 4).
  2. #2
    JK Super Freak AZJeeper's Avatar
    Join Date
    Sep 2007
    Location
    Arizona
    Posts
    1,499
    Ouch! That's why the TPMS comes with the gray caps. Not only so you know there's a TPMS sensor inside but so there's something that wouldn't react to the aluminum stem. You just performed a science experiment called "Bi-metal electrolysis corrosion"!
    You CAN get rid of the TPMS Sensor if you don't mind the ding (x5 assuming you do the spare too) and can live with the butt symbol (_!_).
    You can disable the TPMS with something like the AEV Procal, but that will set you back ~$129. May be cheaper to try to find a deal on Ebay for the sensors. Or live with the down sides. Your choices!
  3. #3
    Join Date
    Jan 2008
    Location
    Texas
    Posts
    10,298
    Those sensors break too easily and get expensive to replace. So...
    Remove all the sensors, get a ProCal, turn the system off.
    Or
    Remove all the sensors, don't get a ProCal, and live with the light.
    Either is better than replacing sensors
  4. #4
    JK Super Freak White Widow's Avatar
    Join Date
    Dec 2008
    Location
    Crawlorado
    Posts
    1,028
    i broke one off each trail run i did, i never replaced them.
    Keep an eye on your girl.
    i work my rubbers like a turnpike
    The Cage
    White Widow in action
    Seats for sale
    northridge4x4.com
  5. #5
    JK Junkie Suffolk JK's Avatar
    Join Date
    Jan 2008
    Location
    Long Island, NY
    Posts
    2,319
    Like stated above, get the AEV ProCal and turn the system off, which I did. Or, live with the TPMS chime/light.
    2008 Jeep Wrangler X 2DR dubbed RED WONDER WAGON by Evan
    Lots of mods.
    Long Island Off Road Club
    liorclub.org/Members/dimi
    NOVA4x4
  6. #6
    Banned riverzendz's Avatar
    Join Date
    Dec 2007
    Posts
    1,235
    x3 on the ProCal. Get that and shut off your TPMS.
    2008 Black Unlimited
  7. #7
    Join Date
    Oct 2007
    Location
    Michigan
    Posts
    18
    WILL the normal valve stem actually fit into the hole in my factory wheel ?
    Does anyone sell just the alunminum valve stem piece?
    I agree in the long term to replace the TPMS units, or use the procal tool. For now I want to save the $$, I can take care of it later.
  8. #8
    Join Date
    Jan 2009
    Location
    Harlingen, Tx
    Posts
    102
    Funny thing happened with my sensors. I have an 07 auto 4 dr and i took it to get the new wheels and tires put on. Told the tire shop about the sensors and had the new stems ready. Turns out my factory wheels did not have sensors....? We checked all the wheels and not one had it. I couldnt explain it, but it turned out to be a lot cheaper. Not sure why mine did not come with sensors.
  9. #9
    JK Junkie jkkat's Avatar
    Join Date
    Dec 2007
    Location
    Everett, WA
    Posts
    2,578
    X many on the AEV Procal and disabling the system.
    07 2 Dr JK Rubicon named RubyDoo in black
    TeraFlex 2.5" BB with 4Dr Ruby springs
    Warn front and rear bumpers
    Skid Row engine/trans skid plate
    rear box 30"x36" full of tools and stuff
    High lift 4' on rear roll bar
    8274 warn winch
    PIAA 5" lights on windshield mounts
    Cragar 345 steel wheels in silver
    Riddler diff covers
    35x1250x17 procomp Xterrains
    Yukon 5.13 gears
    Alloy USA front CroMolly shafts
    TeraFlex 2Lo kit
    www.northridge4x4.com
  10. #10
    Join Date
    Oct 2008
    Location
    Wenatchee, WA
    Posts
    367
    I don't think the 07's had the sensors if my back reading is correct.
    Jeff Davis, Wenatchee, WA
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
