Can I tow a Camper with my JK?
Yes..you have plenty of tow capacity for a light weight hybrid camper... see this thread for ideas...
Jeeps and Campers
I towed a Starcraft 18SB for two seasons with my 4 door Rubi. Just get a good brake controller, weight distribution hitch and maybe think about adding some rear air bags in the springs.
Jeeps and Campers
Jeeps and Campers
Jeeps and Campers
The fact that you can tow a 3700lb (Gross camper weight) doesn't mean you should, we need to be careful not to strain our Jeep components...
Take a look at this: Spree Escape E16RBT
Unloaded Camper weight = 2,398lb
Gross camper weight = 2,800lb
Dry Hitch Weight = 293lb
According to the manufacturer spec page, only the furnace is optional, I could be wrong...
Yeah I wasn't kidding. I tow at my limit (2000) for my 2dr and I don't have a trans cooler. I have never gotten any hot oil lights. And I've tackled some decent hills on hot days. I know the trans cools from the ac condensor. The owners manual suggests it too. This is NOT the case for a manual trans.
The relationship between the A/C condenser and the transmission cooler is not that the condenser pulls heat from the transmission cooler. The condenser has its own heat dumping issues to contend with.
If having the A/C on provides a benefit to transmission cooling, it's only that the fan will be on, drawing more air through the grill, the condenser, the trans cooler, and the radiator.
I would consider installing an aux transmission cooler if I were going to tow a camper.
And make sure the rear axle has synthetic 75W-140 oil in it.
