change tire size or install a lift?
I've got 285/75/16 Rocky mountain tires(load e) and I'm wondering if there the the cause of, what I consider, a rough ride.
Seems I can feel every slight bump and deviation in the road thru the frame to my seat. Wondering if by changing to duratracs( same size,also load e) if it will improve the ride any? I haven't put a lift on yet so still stock springs with rancho 9k shocks(set at 2-3).
The tires run at 28-30psi. I dropped them to 20 once (to drive on the beach) but you could tell my looking at it, they didnt bulge at all. I could also change to either a 15 or 17" tire.
Also since it still has stock springs, should I maybe put a lift kit on it(MC is what I'd go with) and see how that changes the ride before changing tires.
Just wanted to get some thoughts from the community.
Thank you
Thank you
I think there's a wide variation in tire "stiffness" - In other words not all load range X tires feel or conform the same. Since those Rancho shocks are dialed down near the softest setting and the springs are stock, tires are about all that's left. Springs in a lift-kit are not likely to be softer than stock, and could be stiffer. You might want to double-check the tire pressure gauge just in case it's way off and reading low (and the tires have more pressure than the gauge is reading).
For comparison, below is a GY Adventure 285/70-17 load range E at 15 PSI rolling off a small slanted rock. Note how the side wall is bulging and rubbing on the rock.
Thanks for the reply, I can see the bulge in the picture. I asked th is same question on another forum and someone mentioned that switching to duratracs of the same load range would result in a similar ride quality so I was hesitant to change it
Like I said before, tires can have similar specs and not feel or conform the same. Having said that, I'd bet that GY Duratracs and GY Adventures have similar stiffness, both are 2 ply sidewall in load range E, and both have the mountain-snowflake winter rating (which likely is a softer tire for ice/snow performance).
I do have a local discount tire and they offer a
"30 Day ride guarantee
We are so confident of our top quality tires, if you are not pleased with your purchase in the first 30 days or 500 miles, whichever comes first, you may return your undamaged tires and exchange them for any others of equal value, or receive a full refund. No questions asked. What’s the gimmick? There is none. We just want you as a customer for life."
I could probably try out the duratracs in 16" variety and see how it does.
