Click
Click
any ideas what could be making this thing click now? as if the thuds weren't enough:
https://youtu.be/EvdxdqG-foE
I too had a very similar click coming from the passenger side only during backing up in certain suspension flexes
I put the front end on jackstands and went around the entire suspension checking everything to make sure everything was tight what I believe the issue was coming from believe it or not is the bracket that attaches to the windshield area right above the antenna.
After mow the bullet tenths to try to isolate the noise in the wheel well area after removing this bracket I could see where the metal had been rubbing against metal
I too had a very similar click coming from the passenger side only during backing up in certain suspension flexes I put the front end on jackstands and went around the entire suspension checking everything to make sure everything was tight what I believe the issue was coming from believe it or not is the bracket that attaches to the windshield area right above the antenna. After mow the bullet tenths to try to isolate the noise in the wheel well area after removing this bracket I could see where the metal had been rubbing against metal
I did remove the lights I had their recently if we're talking about the same thing. I will check them... But this really sounds like it's coming from under the jeep... just the way the sound reverberates.
