Click
Old 04-18-2015, 12:42 PM
RenegadeUL13's Avatar
Originally Posted by Chadc880
Yes that's me!!! I'd love to make a video of it but I'm afraid to remove the bracket again since the clicking noise went away.
understandable, thanks anyway.
Old 04-19-2015, 08:59 AM
Old 04-19-2015, 10:47 AM
update: I ran beside the jeep while my wife drove and it's absolutely coming from the rear end. SUGGESTIONS?
edit: by rear end I mean the back of the jeep....
Old 04-19-2015, 12:05 PM
sea bass's Avatar
I would remove and re-install wheels and and retorque everything just to eliminate that. Or at least loosen and retighten lug nuts
Maybe spin the wheels with them up in the air by hand to see if you can recreate it?
Old 04-19-2015, 01:06 PM
just gone done checking a bunch of stuff and found this: http://youtu.be/vRE414WET4E it may very well be completely normal, idk, so I decided to record and hopefully someone can confirm this for me.
Old 04-19-2015, 02:20 PM
Jeek.OlllllllO's Avatar
Did you remove the little washer on the lugs before you put the after market wheels?
Old 04-19-2015, 02:22 PM
Oh I thought your wheels where after market, check the balancing weights they might be falling off
Old 04-19-2015, 02:26 PM
robsjeep9's Avatar
Are your rear springs coming in contact with anything? Mine made a similar noise over bumps and the one spring was nicking one of the bars(forget which one) over bumps..... Good luck
Old 04-19-2015, 02:41 PM
no sir. thanks
could it be the rear sway bar end links?
Quick Reply: Click
