Sponsored by:
Sponsored by: DashLynx
Need Help Fixing this Hose-thingy to my Axle
Old 07-13-2009, 06:59 PM
RN M OVR's Avatar
Default Need Help Fixing this Hose-thingy to my Axle
Can I fix this myself or should I just bring it into the dealer?
Old 07-13-2009, 07:14 PM
JKMARINE's Avatar
There should be some clips on the frame by the passenger rear tire. If you can't find them, zip tie it along the frame away from your suspension components. It is a breather tube for the axle. Replacement clips should be cheap though.
Old 07-13-2009, 07:23 PM
mkjeep's Avatar
Like jkmarine said, ziptie it to the frame. Then go to the hardware and get some about 15ft of 1/4in fuel line and extend those puppys up higher Front and rear. Get some small band clamps also for where it goes on the axle nipple.
Old 07-13-2009, 08:09 PM
falconfixer's Avatar
+1 you're halfway there to extending them just do what mkjeep suggests and bringing those higher.
Old 07-13-2009, 08:31 PM
RN M OVR's Avatar
thanks. So, just attach to something up high is the solution? Easy as that?
Old 07-13-2009, 08:32 PM
basically, yea. just leave a little slack like it was said so you don't rip it out again.
Old 07-13-2009, 08:35 PM
RN M OVR's Avatar
haha. Easy enough. Thanks! I knew it wasn't a supper big deal, but definitely glad to know it's a 1-2-3.
Old 07-13-2009, 09:20 PM
mkjeep's Avatar
If you don't extend it, at least put a clamp on the bottom.
Old 07-14-2009, 09:06 AM
RN M OVR's Avatar
fixed! Took 1 minute.
thanks! Definitely going to extend it though. That thing has no slack.
Quick Reply: Need Help Fixing this Hose-thingy to my Axle
