Dana 30 axle hub nut size...36mm vs 35mm.
Results 1 to 4 of 4
  1. #1
    JK Enthusiast dan3jeeps's Avatar
    Join Date
    Jan 2009
    Location
    Job's in Kansas, Heart's in Colorado
    Posts
    329
    Default Dana 30 axle hub nut size...36mm vs 35mm.
    In working on my front axle I noticed that my 36mm hub nut socket fits pretty loosely on the hub nut. Not wanting to round any edges on the nut I went out and bought another 36mm for comparison and a 35mm nut socket. The other 36mm also fit loosely while the 35mm fit tightly, almost perfectly on the axle hub nut.
    Is there supposed to be play between the socket and nut? I would not think so. The hub nut does not already have rounded edges on it either. The 35mm is just a better fit.
    Anyone else notice this? I am planing on keeping the 35mm and using it instead of the 36mm.
    Comments?
    2 old CJs, 1 POS Grand Cherokee, 2007 2 door JK.
  2. #2
    JK Freak crazyhorse02's Avatar
    Join Date
    Nov 2007
    Location
    Everett, WA
    Posts
    575
    same here. In fact, I went through the exact same thing. I thought I was missing something at first but the 35 just fit better so thats what I kept.
    07 Sahara Unlimited
    37" Mickey Thompson MTZ's
    OME HD Lift
    JKS Trackbars
    RC Dual Stabilizers
    Olympic 4x4 Boa Front Bumper
    XRC-8 Winch
    and a bunch of other crap that has emptied my wallet...
  3. #3
    JK Junkie sa29560's Avatar
    Join Date
    Apr 2010
    Location
    - - Jeep-topia - -
    Posts
    2,040
    I bought a 36 to do my ball joints a month back. Ended up just tapping on a 35 lightly with a hammer and it worked just fine.
    I was kind of pissed, fifteen bucks for a socket I didn't even use. But it is still in the toolbox. Never know when the use will come
    07 X 1/2 Doors 6 Speed Lift 33s 4.10s
  4. #4
    Join Date
    Jan 2009
    Location
    Posts
    329
    Keep it around to help with an axle u joint repair while on the trail.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
