drag link, vertical play?
Here's a video, don't know if you guys can see it. My passenger side draglink tie rod end is moving vertically. My fear the knocking sound was my ball joints but I wiggled the tire by hand up on jacks. I couldn't pin point it so I recorded it.
What d you guys think?
https://www.youtube.com/watch?v=IMJzXjZC_Lg&list=UUzOrAZzcLBGraXuysGMw-OQ
I can't really tell by the video, but you should try getting a friend to shake the steering wheel back and forth with the engine off, and feel the joint and you should be able to tell if it's loose or not
The stock link ends do have vertical movement. If you take large channel locks you can compress them and see the movement. Side to side movement is not good. check the torque on all the arms and track bar they will knock if not tight.
Yea i took huge pliers to the link ends. All of them have vertical play. Draglink end opposite of pitman arm has the most
