Dry start knocking noise?
this has nothing to do with what oil you are you using. You could fill your engine with molasses and it would make no difference (as far as the noise is concerned). I have studied this problem and from what i have gathered this is a problem with the filter anti-drain back valve being insufficient. Because the fliter is mounted horizontally it tends to drain thus on start up you get a bang; hiss; or chatter noise when it refills. Some brands just do a better job with the anti drain valve then others. It seems that the MOPAR filter is the most consistent with holding its oil. Other people have reported that Purolator Pure One filters also work well in holding the oil in. WIX also makes a good filter that i hear works on the horizontal. I have heard of people having the dry start problem with Mobil 1 (same as K&N); BOSCH; FRAM (all models); and others. Just because it costs 3X more does not mean that it is better.
There are only a few companies that actually make filters. Purolator; Honeywell; Champion; and WIX
You could relocate your oil filter easily so it is mounted in the upright position but this would be a waste of time because there are filters out there that work just fine.
check out the paper end caps hahaha. but still a very cool video
http://www.youtube.com/watch?v=YCjXtmbL1Kk
I am no expert by far, but I will agree with you on your opinion about the drain back valve. I use Mobil -5000 5W-20 non sysnthetic with the Mopar Oil Filter. The Mopar filter I recently put in, seems to be worse than ever. Recently startying to have this issue if my Jeep is not used in 2 days, It usually only happened every 2 weeks if that.
Do those that have this issue also get the real quick dummy oil light on the dash as well? Blinks so fast, my Scan Tool does not even have a chance to read the code, I have 2 scan tools, both read no codes found.
Dry starts are not good, Can those members on here that switched to a different oil filter other than Mopar, give their actual Part # ? Many thanks in advance
It should not matter if a owner of a Jeep like myself who changes their oil every 3,000 miles or 6 months the oil being synthteic or regular oil, it would be a waste of money in my opinion. I thought syntethic oil was for those who want to go longer on thgeir oil changes or carry heavy loads , etc. Maybe I am missing something....lol
P.S. I also know that Chrysler had to change over to different parts manf's for their parts , due to when the big 3 were going under their hard times, Chrysler left many parts vendors hanging , and now certain parts are just not the same quality with Mopar,,, IE Their Batteries and now it seems to be their filters.
Thanks for any input.
SLIM
Hello to all:
SLIM
SLIM
I will find out for you. Part # FIL 1348. Heres a link to it. napaonline.com/Catalog/CatalogItemDetail.aspx?A=FIL1348_0274109723&An=599 001+102009+50038+2038036[/url]
Yep this is 90 percent drainback valve and 10 percent oil weight issue. The best anti-drain are Amsoil (Donaldson) and Napa Gold (Wix Filters). Add a 0w oil and you will NOT , I repeat WILL NOT have a dry Valvetrain problem unless you have some serious engine issues.
My 2011 did this when I bought it with 6 miles on it. Switched filter and oil to brands listed above an I have no issues. Same with my 4 cylinder ranger.
Get a good filter.
Get a good filter.
I just changed my oil and used a bosch oil filter, I can now here a tap for the first sec or two on a cold start. Probably going to change my filter to the Napa gold to see if it goes away.
