Sponsored by:
Sponsored by: DashLynx
ESP diable works on 2014
Old 11-15-2013, 04:27 AM
Divi's Avatar
Default ESP diable works on 2014
SO I have been searching the forums and google about this ESP disable trick everybody does to disable the ESP, ABS, and that brake thingy but it only states it works up to year 2012, so I decided to give it a go, the worst that would happen is I would have to solder the wire I cut back together and try to find another solution.
I removed my enter console and found the black box with 4 wires going to it, found the purple with light blue tracer and snipped it, started the Jeep and the ABS and Jeep with lines lit up on the dash. Now to wait for my momentary push button to arrive and wire that bad boy in.
took about 15 mins total, I did a lot of testing, start stop, connect wire, start stop, disconnect wire and so on.
Old 11-15-2013, 07:44 AM
NoRdNdd's Avatar
Haven't heard of this trick. Tried the whole turn the steering wheel this way and then that way trick and I just can't get it to work so I have up. Might look into this one.
Old 11-15-2013, 12:20 PM
SabrToothSqrl's Avatar
Default pics
when you get the button, take some pics!
Old 11-15-2013, 12:45 PM
Divi's Avatar
Will do I will do a nice write up for you all.
Sent from my XT1080 using Tapatalk
Old 11-16-2013, 06:19 AM
Dirty Minded's Avatar
Excuse the newbie question, but why do you want to do this?
Old 11-16-2013, 07:27 AM
orngkrate's Avatar
Off-road use mainly. You don't want ESC braking when you are trying to spin mud out of your tires, etc
Old 11-16-2013, 07:37 AM
Divi's Avatar
And playing in snow.
Old 11-17-2013, 06:23 AM
Doesn't it disable automatically when in 4-lo? Or is that the point, that you want to be able to disable in 4-high or 2wd?
Old 11-17-2013, 06:55 AM
Wrangled's Avatar
There is already a really good write up available on this forum.
ESP Kill Switch Writeup
Not that yours won't be good too, just that there are a lot of great write ups for those that wish to look them up.
It is a handy button for winter conditions, and playtime!
Old 11-18-2013, 07:46 AM
Divi's Avatar
you are right that is a really good write up with Pics. I wont do one ill just link to it.
Wonder why I didn't come across that one in my searches...
https://www.jk-forum.com/forums/jk-w...riteup-260247/
Quick Reply: ESP diable works on 2014
