Has any one serviced throttle body sensor?
Hi all
has any one serviced a throttle body sensor, it has to able to be taken apart. dealer is to expensive.
any info appreciated...........................
PS please dont telL me it is unservicible, everything is servicible, thats what they used to say about a TJ fuel module,...unless you are worreid about warranty( I am not)
Originally Posted by silverwrangler
Hi all
Thanks I cleaned it out already, this is wear issue on a TBS module ( that dealer charges $$$$ for), they basically force you to buy the entire thing, because they wont sell you small part of the module, manily the TPS sensor built into it. I do not have warranty and not to many salvage yard here.
PS I cannot get code on obd2 scanner but the ociliSCOPE picked it up right away, it is small glitch now but is getting worse, $$$$$........................................
I had a bad one on a durango I had a few years back, I got a new one off ebay for 18 bucks and it solved my problem. Im not sure how you would go about servicing something like that. Get a meter start by checking continuity of the plug ends would be a start I suppose
