Sponsored by:
Sponsored by: DashLynx
Leaks and i dont know where to start
Old 10-11-2012, 11:42 PM
big c's Avatar
Default Leaks and i dont know where to start
So I have my hard top on and I have a leak coming down the inside of the door by the b pillar ( where the door meets the car and it run from the top all the way down that painted section any ideas I just got the hard top
Old 10-12-2012, 01:56 AM
Tom009's Avatar
Just took mine in for the same thing. Getting it looked at . There is a pressure test they do .
Old 10-12-2012, 05:03 AM
big c's Avatar
I'm thinking about it I'm going to check a few things then go from there did they fix your problem
Old 10-12-2012, 12:59 PM
big c's Avatar
Anyone else have any idea
Old 10-12-2012, 01:04 PM
ohio12jk's Avatar
I found 2 leaks on mine, wash it with jeep running with vents on high, put lots of soap on seams for top, if there is a leak it will bubble up. I found my leaks at b-pillars at the back corners of the front panels.
Old 10-12-2012, 01:32 PM
silverwrangler's Avatar
Hi all
sometimes a long thin strip of foam, kinda like the stuff used to seal house doors in winter, you might have to shave it down to get it thin, then you gently lift the seal and wedge it behind the spot that is leaking and this will help it fill in spot that is leaking or helps it contour itself better. Doesnt always work, but have seen dealer use this procedure to fix body leaks, other then seal replacment or body panel realignment.............................
Quick Reply: Leaks and i dont know where to start
