Grinding Sound at Startup when cold
Old 12-03-2012, 05:52 AM
  #21
Tag
Tag's Avatar
Mine does this too, i currently have a quakerstate filter on it but next change i will try something else and will see if it still happens
Old 12-03-2012, 06:08 PM
  #22
db09JKU's Avatar
It's weird that I've used the same filter for 60,000 miles with no issue until what might be the last 2 I've used. I'm willing to try a different on the next go around.
Old 12-13-2012, 11:16 PM
  #23
psujeepguy's Avatar
I also experience this issue. I switched to mobil one full synthetic 5w20 and have tried K&N, Mopar, and Motorcraft oil filters. Also added Dura Lube during my last oil change. Nothing seems to have helped. I have a 09.
Old 12-14-2012, 04:03 AM
  #24
Winterwheeler's Avatar
It's your power steering pump cavitating until the fluid warms up enough to flow.
Old 01-10-2013, 10:01 PM
  #25
db09JKU's Avatar
Changed oil again for 3rd time. Ruling that out. Frustrating thing is that I can't get it to do it it in front of anyone.
Old 01-11-2013, 06:28 AM
  #26
yo_marc's Avatar
If it's well below freezing, and the noise sounds like a kazoo -- it's the power steering pump cavitating, (like mentioned above...)
In my experience, it's nothing to worry about. Many of my vehicles have done it; some more than others.
Old 01-11-2013, 09:33 AM
  #27
db09JKU's Avatar
Hmm. Not much below freezing here but is near for our lows. It does seem to only happen when I'm the 30's and below. It does sound like a kazoo!
Old 01-11-2013, 03:30 PM
  #28
shabbernigdo's Avatar
Mine does the same. If i hold in my clutch for a few extra seconds after starting the engine it dosent always do it and even when it does its only for a second.
Old 01-26-2013, 09:51 AM
  #29
db09JKU's Avatar
Guessing my power steering is going out. Fluid everywhere.
ID:	414237   Click image for larger version
ID:	414238   Click image for larger version
ID:	414239   Click image for larger version
Old 01-26-2013, 06:30 PM
  #30
db09JKU's Avatar
I wonder if this is the source to my noise.
Quick Reply: Grinding Sound at Startup when cold
