Heat shield rattle
#21
i got up under my jeep 20 times before i found the problem. had to start bangin around with a rubber malet. thats when I found the problem. the spot where the pipes go from 2 to 1 pipe, one pipe fits in the other pipe and the clamp around it just wasnt tight enough.
#22
my rattle sounds like it is right under me. it occurs when i'm bogged down....like when i start out in 2nd but should have started out in first... or cruising slowly in a parking lot in 2nd.
i had my jeep at the dealership for another minor repair (under warranty) and described my problem. here's a good one: they said it was the shift knob that was rattling, and they replaced it. yeah.... THAT helped. it was free under warranty, so i took the new knob... but wtf. that place is useless.
#23
My front heat shield came loose and it took weeks to figure it out. The dam dealer at 22 and pantano told me it was my fault because I changed the muffler I had to get under the jeep and have the wife rev it till I found it. (on a day she wasn't pissed at me) It was the front heat sheil on the drivers side end. I bought a big hose clamp put it around the shild and pipes..tightened her down and no more noise.....
#26
DONT WORRY BOUT WELDING IT JUST GET A HOSE CLAMP OR TWO AND PUT IT AROUND IT. iM SURE THE WELDS WILL JUST BREAK AGAIN
#27
Same thing here... It was a hair-line crack in the weld holding the heat-shield to an exhaust pipe. I couldn't believe a barley noticeable crack could make so much noise. Clamped it down,,, noise gone!
#29
No Sh%t, I though something was wrong with my tranny. One itty bitty weld on the cross over pipe heat shield. Screwdriver fixed it.
