HELP! Engine Light - Misfire
My engine light came on a couple weeks ago. I had it checked and they said it was a misfire on cylindar 6 due to ignition coil. I bought a new ignition coil and replaced it and since i had to remove the intake alreaey, i went ahead and changed the plugs as well. when i hooked the battery back up and started the engine, the light was off. Boom...fixed...until about 4 days later the ilght came back on. i figured it was a gas cap or some other emissions leak but when i ha it checked again it was "Misfire cylindar 6". I told them i had replace the coil and they asked if i had the code cleared. I told them i didn't and they said it was probably just stored and left over from previous and they cleared the code. Boom...fixed again...until 2 days ago it came back on. I'm assuming same problem. i have noticed that when i'm idling that i feel the engine sort "rocking"...don't know how else to describe it. Jeep is a 2012 JKU with about 64,000 miles on it. any suggestions or help on what to look at next would be appreciated.
Thanks for the info guys. I guess its a call to the dealership then.
Following up on this, I took the jeep in to the local dealer in town (Lucas Smith Dodge) on Tuesday. They confirmed that it was the cylinder head issue and replaced it. I dropped it off on Tuesday and i'm picking it back up tomorrow. They couldn't have been better or easier to deal with on this issue. I don't know if it really made any difference but when i called the dealership, i did mention to them that i found online where Chrysler had extended the warranty for left bank misfires...it may not have made any difference but they asked for the last 8 digits of the VIN and when i told them, they confirmed that it would be covered under the extended warranty.
