Help me get more heat for rear foot passenger...please?
Lava jacket
Check out the ACE engineering lava jacket. They also sell and extension sleeve to use with another jacket for backseat passengers. The sleeve could be used alone to route heat where you wanted.
Any solutions yet? We hit -66C / -86F here last February and I have a new Jeeper expected to be born at the end of November. I'm installing "Astrofoil" (tinfoil bubble wrap) under the carpet and on the ceiling. It's not cheep but should reflect the cold out and the heat in, they use similar stuff in astronauts suits. Any electric heaters anyone has tried? Looking for some success stories to help avoid a kidcicle on the way to grandmas!
Here's a pic from earlier this week so you get the idea...
Your feet are cold in the winter? They make something for this, they are called wool socks, over them you put insulated boots. This is what people have done to keep their feet warm in wet and cold conditions for several thousand years, I have good results with said methods.
Attachment 575573
Attachment 575573
If you just want heat back there and don't care how it looks you can pull out the vent cover and attach a smaller dryer hose and run it back there and have the passengers under a blanket...
I made a little deal for my kids like that when they had gymnastics in the winter, attached the hose to a plastic coupler that was from a metal tube style bunk bed. Probably looked ghetto but it worked and no one really ever saw it but me. When I wasn't using it I could toss it behind the seat and put the vent cover on.
Perhaps some of the responding posters missed the -86 degrees F.
You need some type of heater core run off of the coolant lines to fight off that kind of cold.
Wool socks eh? Winter boots eh? Being from Canada believe it or not I have heard of these things but thanks for the helpful and not sarcastic at all tips though!! Usually I just let the back seat passengers suffer but I'm talking about a new baby. Grandma is an 8 hour drive away, last year on the drive defrost had to be on full blast to keep as much window defrosted as possible (probably going to do the PVC vent mod) and didn't dare switch it to defrost/floor and certainly not vent. Cardboard in front of the radiator only helps to keep more window defrosted. 1/4" tubing around rad hose then to windshield washer nozzles helps the vision.
Like the idea of a heater core but couldn't find a write up. I guess go to the wreckers and wing it. Probably going to do heated seat covers too.
Thanks for the ideas I gotta do something or my wife will trade my Jeep for a minivan *shudders looses sleep*
Don't let that stop you. The little heaters come with installation instructions. You'll probably be the first to install one in a JK.
I've seen these in action, in cars and step vans. It's really the best way to go when it's down to the temps you see.
Here's an example: Aux Heater
