HELP! Transmission noise--shifting from R to D and the aftermath
JKU- 2007 Sahara auto w/ 35s & 2.5" TF coil lift. 99.5k miles. Programmed with AEV ProCal to compensate for tire height.
I returned from the gym this AM and put the JK in reverse to back into my garage. About half way up (10' @ most) I hear 2 loud "clunks". I stopped and did a walk around. No leaks. Nothing evident of a failure. Got back in and pulled it into the garage.
Evidently enough, I was going to take her down to ORW this morning to have them inspect the front end as I have been having an issue with a shim in the steering (whole different issue). While in the garage, I place the JK into drive, and hear the transmission move into gear. Curiosity spiked. I cycled the transmission from reverse to drive a few times and found a horrible noise. Once in drive, and out of the garage while traveling down the street, the JK makes a horrible noise while accelerating; something like driving over the washboard on the shoulder of the road. It stops while coasting.
I had my wife cycle the transmission from drive to reverse and vice versa. here's a sound clip. Anyone have any ideas as to what is wrong? Anyone experience this before? Im chicken shit to drive it anywhere too far...
http://youtu.be/ai-reI2w_H8 I had the transmission serviced within 10k miles. The shop claimed there was plenty of metal shavings and would appear it might have been its first service. Its ran smooth since. I only had it services because I noticed the gasket began to leak.
Here's a better quality video that illustrates my problem...
https://www.youtube.com/watch?v=vz26ATLOFuc
Doesn't sound normal to me, either.
What kind of service did you have done? Just maintenance or was there a problem? Filter and fluid? At a dealer or independent shop?
I'm wondering if someone put in fluid that isn't ATF+4.
How does the fluid look? Bright red? Any burnt toast smell?
