How do I identify "bad" engines in oil consuming 07-08 JK jeeps?
Originally Posted by Ryan0260
Not necessarily but it does seem to be a symptom of the bad motors. Mine is doing both also and started my consumption test last month. My pinging seems worse when it is hot out and more so when the oil is getting low. I am anxious to see how much it has lost next time
Mine is fine. It burns about a half a quart every couple thousand miles. And it's an 08 with 84000 miles. The only problem I have is with it jumping out of first.
What year is yours?
What problems do you have? What do your plugs look like? Picture of plugs?
I won't have a chance to do an oil consumption test, but I can check oil level and pull a plug.
Thanks for your help!
They'll be black and sooty looking and probably slick with oil, and if enough oil is entering the combustion chamber they may have peeling black carbon deposits on the electrodes. Healthy plugs look dry and are just dusted with a greyish brown coating (not to be confused with plugs that are burnt white or very light grey which is a sign of a motor running too lean & hot).
Used to be you might tell by running a finger around the exhaust pipe outlet if it burned oil bad. That may no longer be true with cat converters though, not sure.
If they are smart enough to fill the oil and put fresh plugs in, might be hard to tell.
