Sponsored by:
Sponsored by: DashLynx
How do I reset my oil change light?
Old 07-28-2011, 11:55 AM
  #21
DanieltheManual's Avatar
Up, down, up down, left right, left right, a, b ,a, b, select, start.....lol
Old 07-28-2011, 12:07 PM
  #22
jslashk's Avatar
Contra unlimited lives? Classic.
Old 01-04-2012, 08:16 AM
  #23
nate_every's Avatar
I have been trying to get this too work aswell, I am thinking I might just be pressing the pedal too fast...
Old 01-04-2012, 08:24 AM
  #24
daggo66's Avatar
Originally Posted by djjakubik
I tried the pedal method and my light did not go off...I have tried it numerous times. Any other methods?
Turn the key two clicks. Three clicks starts the engine. Do not start the engine. Fully depress the pedal 3 times, then turn the key all the way off.
Old 01-04-2012, 04:28 PM
  #25
Deep Water Terp's Avatar
I just reset mine the other day. Turn the key to the first click and press the gas pedal three times. Then turn it one more click and press the gas pedal 3 times. Turn it all the way off, then start it up. That should work. Good luck!
Old 01-05-2012, 07:31 AM
  #26
Weezerpiebald's Avatar
I had mine going off for almost a month before I decided to look it up
Old 05-30-2015, 11:36 AM
  #27
druminstein's Avatar
Default Best way to reset that oil light
Darn thing keeps beeping when I start the Jeep, but I changed the oil already. Also are there any lube spots I need to hit under the Jeep when I change the oil?
We use this at the shop all day long:
Reset Oil Life Remaining Reminder Light on Jeep Cherokee
They have an app too, if that light keeps going off its a lot faster to use the app and wont chew up all your data while youre out and about. hope it helps
Old 05-30-2015, 11:59 AM
  #28
Tooadvanced's Avatar
^^^^^this is the correct way
Old 07-15-2015, 10:47 AM
  #29
Freightguy's Avatar
Is there a way to eliminate the indicator all together? Mine comes on about 500 miles after and oil change, resetting the clock gets me another 50 to 100 miles. Something aint right with mine and I would like to just do away with it.
Quick Reply: How do I reset my oil change light?
