I can't remove the 4wd shifter knob
Not sure why this is in electrical, but the answer is pull harder. Might help to put it into 4wd and pull straight up. Just don't punch yourself in the face. If you do punch yourself in the face, pics would be appreciated. lol
Because he is working on the stereo. Duh.
Sorry, kidding.
Get a shop towel or bath towel, a 8" crescent wrench and a hammer.
- Engage the E-Brake and shift the transfer case to Neutral.
- Open the Crescent and lay a part of the towel on the jaws.
- Put the jaws on the metal of the shifter shaft and close the jaws to kind of snug. Not tight. The towel is there so you don't scratch the paint on the shaft or the plastic on the shifter.
- Drape the rest of the towel on top of the knob or have someone rest a hand on the knob. This will prevent the knob from flying up.
- With the hammer hit the bottom of the crescent wrench. It will come loose on the third hit.
The first hit won't be hard enough. The second hit will be harder but still not quite. Now that you are adequately angry at the knob and the situation...The third hit will pop it loose.
Sorry, kidding.
I still cant get the damn thing to come off. I have had two other guys try as well. Should I try some wd40?
Btw: The reason it was in electrical was because I am running LEDs in to my center console and need to remove the center piece two propoerly drill the holes and run the wires. I was succesful at running my footwell leds with a on/off switch and it looks awesome. Just wish I could finish the rest of my project.
Don't use wd-40, put it in 4lo, and wrap a towel around the knob tightly. Then give it a couple really hard yanks will come right off with some more leverage from the towel.
