Jeep wont start
Insurance guy came out and says I'm shit out of luck. Wife's 9 months prego so I really need my jeep up and running asap. Anyone got any other ideas?
If the neutral trick does not work you're most likely going to start having to check to see if you have a loose ground somewhere. If you have a meter start checking from the battery to the starter with the key on. Could be the collision knocked a wire loose somewhere.
Have you tried checking the negative terminal to your battery? Mines loose as hell and every so often fails to make proper contact preventing the jeep from starting. I just wiggle it around and it fires right up. One day I'll replace or tighten it...
