JK Oil Burning?
JK Oil Burning?
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: JK Oil Burning?
  1. #1
    JK Newbie Detyellow2008's Avatar
    Join Date
    Apr 2009
    Location
    Ohio
    Posts
    59
    Default JK Oil Burning?
    I have read a lot about the JKs and their oil burning potential. I changed mine yesterday and got almost five quarts of used oil after about 5k miles. My reading on the dipstick was below the "normal" range before the change. Does anyone know how low would the "actual" oil level needs to go in order to cause engine damage?
  2. #2
    JK Jedi Master ronjenx's Avatar
    Join Date
    Feb 2008
    Location
    Maine
    Posts
    11,961
    There isn't a specific answer to your question.
    Less than the recommended quantity of oil means the oil needs to be changed more often. One quart would go bad before 6 quarts.
    If the quantity is low enough to cause the oil pressure light to come on when accelerating, braking, going uphill or down hill, and turning corners, then a little damage occurs each time the light comes on.
    Quantity low enough so the light stays on, damage is happening every second the engine remains running.
    I'm sure you knew all that. I'm just illustrating there is no specific quantity where damage starts happening.
    08 Rubicon Unlimited
    Auto Transmission
  3. #3
    Join Date
    Oct 2010
    Location
    Gardner, MA
    Posts
    73
    This seems to be a huge problem for these 3.8l Jeeps. Mine did the same thing lost about 1/4 -1/2 qt between changes until I began using the proper oil weight 5W-30 and now it stays full!
  4. #4
    JK Freak jjntj2003's Avatar
    Join Date
    Mar 2011
    Location
    mccalla alabama
    Posts
    955
    I know this is a different beast but my wifes traverse has the 3.1 chevy in it and they told me all new aluminum motors use between 1-1 1/2 qts between 3500-5000 miles on an oil change. I told them b.s. A car with 12,000 miles should not burn oil so now we have to go to dealership every 500 miles so they can do an oil consption test.
    The way I guess it is now every fill up check the oil while pumping!!
  5. #5
    JK Enthusiast im-ocd's Avatar
    Join Date
    Jan 2011
    Location
    USA
    Posts
    141
    Quote Originally Posted by Detyellow2008 View Post
    I wouldn't be too concerned.
    About +- 60,000 miles ago my wife's 07 Grand Caravan with 3.8 motor was taken in for oil change on an impromptu trip; to my surprise they said the oil level wasn't showing on the dipstick! I didn't know the van used oil, even though I'd been changing it every 3,000 miles.
    After that incident, there was another instance when the oil was barely on the dipstick.
    In both those cases the oil was about 1.5-2 quarts low No light ever came on, the temperature was normal and there was no indication of a problem.
    I've since kept a much closer eye on the oil level.
    We have continued to drive the van without any obvious problems.
    2010 Jeep Wrangler Unlimited
    Oil changes at 6,000 miles? No way! My goal is for the motor to last as long as possible, not the oil.
  6. #6
    JK Super Freak AirJordan613's Avatar
    Join Date
    Sep 2010
    Location
    Beachwood, Ohio
    Posts
    1,337
    After revving up to about 5 grand on an on ramp I could smell what seemed like burning oil from the cabin. Is this normal? Note: it was a very short on ramp.
    2008 2DR Sahara, AEV 3.5, 35" Duratracs, G2 4.88, F/R Eaton E-Lockers, Quadratec Q9000
  7. #7
    JK Freak XBlacky08X's Avatar
    Join Date
    Oct 2010
    Location
    Holyoke, MA
    Posts
    536
    My JK is just shy of 40K miles and it does not burn a drop of oil. Stays full between changes and I check it regularly.
    OLD: 2008 Bare Bones X 6spd... RIP
    NEW: 2013 Crush Auto w/3.73's...
  8. #8
    JK Enthusiast kashlak's Avatar
    Join Date
    Aug 2007
    Location
    baltimore md
    Posts
    453
    My husband constantly bitches about my oil being low. He just checked it this passed weekend and was a quart low. From what I am reading on here this is a common problem. Mine is a 6 speed not an automatic. He calls my jeep a piece of shit but I still love it.
  9. #9
    JK Freak Dronac's Avatar
    Join Date
    Jan 2010
    Location
    Charlotte, NC
    Posts
    726
    I guess I lucked out. Mine doesn't burn a drop even on 6k intervals. I usually stick to 5w-30, but I'v never burnt any 5w-20 either.
    Just do what the owners manual says. Check it when you gas up. As long as it isn't fouling up the combustion chamber and you keep it topped off, it shouldn't cause any problems. I would run some seafoam once a month if your burning alot of oil to keep the combustion chamber clean.
    2008 Two door X w/ 24/s package. Auto Trans w/ 5.13 gears.
    Rusty's 2'' coil lift (3'' lift gained)
    33x15R12.5 Goodyear Duratracs on 15'' Soft 8's
    Cobra 75 CB
    JKS Discos
    Onboard MV-50 Compressor
    And many more...
    In Progress: Inverter, Tire Carrier
    http://northridge4x4.com <--- Go there and buy stuff. You won't be disappointed.
  10. #10
    JK Junkie 07JKX's Avatar
    Join Date
    Mar 2007
    Location
    Kennesaw, GA
    Posts
    2,710
    i replaced my pcv and that fixed the oil consumption on mine. However, now I found leakage at either the timing cover or the crank seal. Gonna clean up the motor tonight and hope I can pinpoint the leak. Hopefully its not both places
    2007 Jeep Green Wrangler Unlimited
    TF 2. 5" BB
    PA 1" BL
    16x8 Cragar Soft 8's
    33" AT's
    Cobra CB
    On Board Air
    Superchips Flashpaq
    Hi-Lift
    PJ Front Stubby
    Ramsey REP 8500 w/in cab controls
    Lots O' Lights
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
