Leveling Spacer
Leveling Spacer
Hello,
I have a 2015 Wrangler 2 door and want to eliminate the stock rake. I DO NOT want to lift the Jeep. Does anyone know what size spacers I need up front to level it? I assume either 3/4 inch or 1 inch. I will not be adding any weight to the front like winches or bumpers. Also will I need an alignment after or just center the steering wheel?
Thanks in advance
Thanks in advance
Hello,
Thanks in advance
Thanks in advance
Leveling Spacer
I also wanted to eliminate the rake, I first had them install 2" spacers in front and it raked the other way slightly so they added 3/4" spacers in back and it was perfect.
I am just repeating others words. I used a 3/4" spacer in the front (only) to level my 2 door when I first got it.
If your alignment is good now, it will not need any adjustments after the spacer install. Some need just a tweak to straighten the steering wheel.
One other thing; You are not the first JK owner to say you are not doing any other modifications in the future, this forum is full of them/us.
Here's what we are doing and I can't say this is a leveling kit.. thou I may alter these plans as we progress through the process.. But Daystar sent us their lift kit shocks and spacers.. the kit says.. 1.75.. but the spacers measure 2'' inchs.. So I'm considering either removing all the factory spacers and using just the daystar versions.. Mind you one set of spacer are slightly more than 2'' inches (rear) while the other set of spacer is slightly less than 2'' inches (front).
Even though I've posted that I'm removing the factory spacers.. I may actually leave the front one in and simply removing the rear one.. In essence.. the rear would have the 2'' inch spacer.. while the front would have the factory .75 + the 2'' inch spacer..
At this point, I'm wondering if this would level the jeep or tilt it back more.. Something to ponder cause I actually want more of a lift in the back to make up for any added weight..
LOL true! I have had so many lifted trucks that it is so nice having a brand new Wrangler that clears 33's right out of the box! Things can change sure but I doubt it. Been there, done that. I am enjoying this Jeep and the factory ride as long as possible ;-)
