a little help
a little help
I had the Jeep pared in my driveway or a couple days. Shoveling snow this morning, I moved it to find fluid leak under right front. Looks like power steering fluid, but I can't figure out from where. What does steering stabilizer fluid look like. Haven't had time to check it out. Anyone have issues like this. BTW I had right tire up against stop I keep to prevent hitting the wall
Steering stabilizer fluid is just light hydraulic oil and should be clear to a light brown color. Transmission cooling lines are known to leak on the automatics and your coolant is red in color and could come from the overflow.
When I first got mine I had some leakage in the garage and couldn't see where it came from, finally found it coming from the front diff breather - they overfilled it from the factory. Might check all your fluid levels ....
