Mobile 1 GF-5, 5w-20 Does not list MS-6395
I have been using Mobile 1 GF-4, 5w-20 which does meet MS-6395. The new Mobil 1 5w-20 has now been upgraded to ISLAC GF-5, and the MS-6395 spec is no longer on the container label. What bothers me is that Chrysler Materaial Standard MS-6395 is also NOT listed on the Mobil 1 material data sheet. (See below).
Does anyone know if the new Mobile 1, GF-5, SAE 5w-20 meets spec MS-6395 ?
http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx
According to ExxonMobil, Mobil 1 5W-20 is of the following quality level: FordWSS-M2C930-AGeneral MotorsGM 6094MAPICF
I went and picked some up Saturday. I noticed the same thing. Bought it anyways. But it would be good to know for warranty issues. I have used it before and it has always had the Chrysler info on there.
I have an older bottle of mobil-1 5w-20 in the garage and it has ms-6395 on it. I did notice that the 5w-30 didn't have it on it for the longest time but now that the 3.6, which calls for 5w-30, is in almost everything across the lineup, 5w-30 NOW has ms-6395 on the label again.
Bump to top. Anyone? I noticed this same thing last time I was buying 5w-20. They had an older bottle with it on there and another which didnt... I bought the one that had it written... Very curious bout this!
I just read this...
When I heard that Mobil 1 did not meet the MS-6395 specs... I was like... Whaat!? For reals?. So I had read up and came to the understanding that Mobil 1 and Chrysler has some sort of fall out. That Chrysler MS-6395 had changed some of it requirements, so to be approved by MS-6395 Mobil 1 would have to be tested for like two years! I then thought back to when I was at the dealership and I did remember them using Mobil 1. So I was like WTF.. over. Well to get to the point.. I wanted to keep my integrity so I started to look for oils that met the recommendation. I had decided that I was going to use Pennzoil Synthetic Oil, but all along still wanting Mobil 1. Well I just read this today.
This is for Mobil Super (I believe either a non or some sort of half breed synthetic oil). It is the product description, features and benefits, applications, specifications and approvals. Look what it says about Chrysler MS-6395, under Specifications and Approvals.
Mobil Super
This Mobil Super Synthetic and look what it says about Chrysler MS-6395, under Specifications and Approvals
Mobil Super™ Synthetic
Now, check this one
Mobil 1 5w-20 Advanced Full Synthetic Engine Oil
Mobil Super
Now, check this one
Mobil Super
Now, check this one
Mobil Super
Now, check this one
I think that last year Chrysler changed the specification for MS 6395, so now Mobil 1 has to be re certified. My guess is that after another season of testing the current Mobil 1 will prove to meet/exceed the Chrysler MS 6395 specification. Also, I think that Mobil 1 is a higher quality than Mobile Super Synthetic (which is also fully synthetic), although Mobile Super Synthetic does meet MS 6395. I am not familar with Mobil 1 Advanced Fuel Economy other than it is suppose to provide marginally better fuel economy. For now, I am staying with Mobil 1 SAE 5w-20 GF-5, as I am betting that it will be re certified (next year) to MS 6395. It was previously certifed to MS 6395 prior to Chrysler changing the specification.
Here is what Exxon/Mobil say:
http://www.mobiloil.com/USA-English/...r_MS-6395.aspx
Mobil 1 | Chrysler MS-6395 Specification
[TABLE]
[TR]
[TD="class: cnhdr-blue"]Question:[/TD]
[/TR]
[TR]
[TD="class: boldBodyText"]Mobil 1 5W-20 and Chrysler MS-6395[/TD]
[/TR]
[TR]
[TD="class: bodyText ContentAreaPadding"]Why is your Mobil 1 5W-20 not Chrysler MS-6395 spec approved? Or if it is, why is the certification not on the bottle or website?[/TD]
[/TR]
[TR]
[TD="class: bodyText ContentAreaPadding"][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD="class: cnhdr-blue"]Answer:[/TD]
[/TR]
[TR]
[TD="class: bodyText ContentAreaPadding"]Chrysler’s latest revision to the MS-6395 specification calls for a field trial spanning multiple seasons over two years. While we fully expect the exceptional performance of Mobil 1 synthetic motor oil to meet Chrysler’s specification requirements, at this time we are in the process of evaluating our timeline to start this testing.[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TABLE]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
SAE 5w-20, meeting MS-6395. Chrysler did not recommend SAE 5w-30 for the 3.8 L cast iron block engine. I am not sure there is anything wrong with using 5w-30 in a warm climate, but you are in Ohio which does have cold winters. I think Chrysler speced the 5w-20 for better flow for cold starts and better fuel economy etc. Ford also recommends SAE 5w-20 in some of their engines. GM does not recommed 5w-20, but 2 years ago, switched to the Cognos speced engine oil which is a higher quality oil than the previous oil speced by GM.
If you read the container on some SAE 5w-30 engine oils, I think some meet the MS 6395 spec (such as Pennzoil Platinum) but it is still not the correct viscosity as specified by Chrysler for the 3.8 L cast iron block engine.
Good luck with your studies in Mechanical Engineering. I studied M.E. at University of Missioui - Rolla.
