Mopar MS-9224 equivalent?
Ok changed my front and rear diff fluid , (mobil one 75-90) changed my transfer case fluid ATF-4 , want to change my Manual Trans fluid but can't find anything but dealer sold Mopar MS-9224 . Does anyone know of an equivalent to this in say a ...mobil one synthetic product or any synthetic???
so far from what i have found amsoil is http://www.amsoil.com/catalog.aspx?code=MTFQT-EA that but if u already changed it. let me know what you found out cuz i am just about to change mine
The only 2 products I found that met MS-9224 are Pennzoil and Quaker State Synchromesh. Don't pay any attention to any threads you find where people are talking about buying Synthetic Synchromesh, as far as I know all of the stuff is Synthetic to begin with. BTW Royal Purple Synchromax does NOT meet MS-9224, like estam7655 said Amsoil Synthetic Manual Synchromesh Transmission Fluid is another option that meets spec too.
I picked up some of the Pennzoil Synchromesh at a local NAPA here in CO for eight dollars a quart.
Last change was 20k ago, fluid came out good as new, as well as the ATF from the T-case.
From what I understand, one of the "weights" applied to searches on Google involves "personalizing" it to the user. Your cookies tell Google that you visit the forum often so it gives it a higher rank in the results.
Just tossing in another repeat comment....local NAPA was the only place I could find the MS-9224 compatible fluid....Pennzoil and Quaker State.
Edit....I had asked here about how much fluid was needed. From reading other threads....I see anywhere from 1.6 to 1.75 quarts required to fill.
Grant
Grant
