Sponsored by:
Sponsored by: DashLynx
OEM Radio Compatibility
Old 10-22-2016, 08:54 AM
JeeprCreepr13's Avatar
Default OEM Radio Compatibility
2008 Jeep Wrangler 2 door
The auxiliary port on my stock radio is messed up. I found one on Craigslist that looks exactly like mine. The person that posted it is unsure if it will work in my Jeep and I can't find any site that show me what's compatible. I'd just like to replace it because I'm really not a fan of the look of aftermarket radios. Is there a site that I can check out for compatible oem parts? Or is there a site that sells oem parts? I didn't find it on the Mopar site.
Part: P05091226AC (Mine is the Sirius version too)
Thanks in advance!
Old 10-22-2016, 09:59 AM
karls10jk's Avatar
If it's touchscreen then you've got to check part numbers. If it's a standard radio and the mounting points look correct, as well as the face of the radio then why not head over and plug it in before you buy it to test it?
Be sure to get the anti-theft code from the seller. He'll need the part number, the VIN number, his info, and just contact your local jeep parts department.
Quick Reply: OEM Radio Compatibility
